Sicle Mower - Can it do this?
Tommy D
05-10-2004 09:12:01
My uncle, who passed last year, has an older Ford brand sicle mower that I might make his estate an offer for. My questions is does this have to be parallel to the ground to mow?
I have some roadsides that are sloped between the road and my yard at about a 45-50 degree angle upwards - more than I am comfortable with putting my tractor on with a brush-hog.
Is it possible somehow to only lower the mower to this angle and mow, or does it need to be parallel to the ground to mow.
All guidance is greatly appreciated.
Tommy D.
paul
05-10-2004 09:45:29
 Re: Sicle Mower - Can it do this? in reply to Tommy D, 05-10-2004 09:12:01
Parallel to the ground is the way to mow, you are concerned about the angle between the mower frame & the sickle bar.
Those with a wobble box driving the sickle can handle extreme angles, those with a pitman stick (wooden bar between the belt pulley & sickle ball) don't like to get more than 15-20 degrees - more or less.
If you don't know the difference, what model Ford mower is it?
--->Paul
Tommy D
05-11-2004 08:48:23
 Re: Re: Sicle Mower - Can it do this? in reply to paul, 05-10-2004 09:45:29
paul,
I honestly don't know the model number at present. Last weekend we were driving by and I saw all his old implements in a shed:
Ford Square Baler
Ford 1 row Corn Picker that mounted on tractor
Ford Sicle Mower
et. al.
From what I remember, the mower has a tubular half circle looking mount and does drive with a belt.
I will look again weekend after next (It's 80 miles away). I assume there will be an ID plate somewhere?
Anything else that might ID it?
Thanks for your input!
Tommy D.
paul
05-11-2004 12:06:01
 Re: Re: Re: Sicle Mower - Can it do this? in reply to Tommy D, 05-11-2004 08:48:23
Basicically if it has a wooden stick (or some few are metal) that directly drives the sickle by stroking back & forth, it is an older model like a 501 or 14-92 (which are for all practical purposes the same). If it has a little gearbox device down by the sickle and a longer belt to that box and the box makes the sickle go by wobbling internally, then it is a newer wobble-box drive type. I think they are something like a model 450 or so????
I'll guess it is the older style from the rest of the equipment.....
I have both a 501 & a 14-92 (I think I got those # right, close anyhow) and use it to cut all my road ditches & water ditch banks, works fine. However, the more they angle, the harder they work or wear. The wobble type are better as they can angle all which ways. You would probably prefer a newer wobble style, however you probably will get along fine with the pitman stick. Probably, but I don't know.
The model # on mine are on the right side, a plate rivioted onto the breakaway arm.
Also, they had different setups for making the mower bar raise & lower, some don't work as well with non-Ford 3pt tractors as they clamped right onto the side of a tractor arm. As I have a 960 Ford I've never worried or thought much about it, but that's what I understand.
--->Paul
