Can't get PTO shaft on!!!!
COLBY N TX
05-08-2004 17:41:14
After my bushog sat out all winter I can not get the yoke to lock on to my PTO. The three balls inside the yoke seem to be froze up. I have soaked then in oil and they wont budge. They will spin just not recess so it will slide over the pto. Any help would be great.
Thanks,
Colby
Alvin NE WI
05-08-2004 19:51:53
 Re: Can't get PTO shaft on!!!! in reply to COLBY N TX, 05-08-2004 17:41:14
use some WD40 and a hammer to tap those little critters. Maybe this fall you will remenber to put the pto shaft in the shed. Sheds to prevent a lot of problems when it gets to be time to use something.
Dave H (MI)
05-09-2004 07:23:38
 Re: Re: Can't get PTO shaft on!!!! in reply to Alvin NE WI, 05-08-2004 19:51:53
Yup, use the little red straw on the WD40 and blast it right in where they are seized up. I also take a soft brass wire brush and clean the tractor side and then hose it down with WD40 to make sure there is no grit. You would be amazed how little sand it takes to make these tough to get on.
