IH 47 Baler Repair Question
Richard
05-06-2004 06:03:25
Broke old Tess last night. The links that go to the pick up to the gear gizmo broke. OK need to replace that one, no biggy.
Upon closer inspection that shaft that the links and chain attach, one of the bearings blew up. I noticed on one of the cogs (outboard) had a pin and cotter pin the other one didn't. Does the inboard cog come off differently or is it supposed to have a pin and cotter like the other one???
Am I making sense or more clarification needed.
havvey
05-07-2004 05:39:16
 Re: IH 47 Baler Repair Question in reply to Richard, 05-06-2004 06:03:25
most ih balers had a slip clutch on the head and a shaft with bearings behind it a parts/ repair manual might help you alot.
Wayne Kittler
05-06-2004 20:19:25
I think you mean the gear that drives the pick-up unit. There is suppose to be a slip clutch there. Soak it good and take the pin out. In time you should be able to slide it off. The inner may be part of the center pick-up drive.
