JD 350 side rake bearing
Phil - MO
05-05-2004 05:31:59
I need a NICE 7138 bearing for a John Deere 350 side delivery rake.
The industrial John Deere Dealer and the Agriculture JD dealer can not find it.
Bearing distributors in St. Louis can't match it up.
I may have to buy the hub assembly for over $100 from a JD Ag dealer in Illinois if I can't find it.
Phil
Tim(nj)
05-05-2004 09:47:50
 Re: JD 350 side rake bearing in reply to Phil - MO, 05-05-2004 05:31:59
Is this a needle bearing?
Have dealer check dimensions on JD8832 bearing if it is. Pull-type rakes used this bearing, maybe 350 used the same thing.
JMS/MN
05-05-2004 12:40:23
 Re: Re: JD 350 side rake bearing in reply to Tim(nj), 05-05-2004 09:47:50
Tim has it right- my local dealer confirmed the JD number is used on that rake in several locations, and has them in stock. We do have some dedicated partsmen around here.
Jerry D in NC
05-05-2004 07:06:13
Can you get a match of the inside and outside diameter???
Phil - MO
05-05-2004 10:38:33
 Re: Re: JD 350 side rake bearing in reply to Jerry D in NC, 05-05-2004 07:06:13
I have the bearing and measurements outside in the car and I'm at work.
I believe the OD was 2.312 or roughly 2 5/16 and the ID was 1.270 which is 1 1/4 plus 20 thousands? and it has a shoulder on it.
I took the bearing to the two biggest bearing distributors in St. Louis and they couldn't match these dimensions up or even come close. I guess it was special dimensions for John Deere for proprietary rights. In other words they can set the price if you want it. And they don't stock it now.
I guess I'll bite the bullet and buy the whole assembly for $100 plus. I bought all new spring teeth, etc. already. Sure is fun keeping 40 to 50 year old equipment going, isn't it.
My wife wants to know when we are going to start making a profit on the cattle? I forgot to tell here I am going to retire and this was just a hobby.
Be careful putting that hay up.
