Over ride PTO clutch
Jed
05-04-2004 07:29:34
Perhaps I am having a senior moment or maybe I am just stupid,but what holds one of these clutches on the PTO shaft. I bought an over riding PTO assembly when Central Tractor was closing. It is made for a small shaft Farmall and has a new size equipment end on it. The affair has 2 grease fittings and the female inside end has a snap ring in it. What holds it on the PTO?
Norm
05-04-2004 10:35:42
 Re: Over ride PTO clutch in reply to Jed, 05-04-2004 07:29:34
Under the grease fittings is a roll pin which you remove, line up the holes, replace the pin and the grease fittings, assuming you have a hole in the pto stub. More better is a clutch with a spring loaded release.
