311 Baler knotter trouble
link
05-03-2004 16:29:10
My 311 seems to be tying ,but keeps breaking twine after the knott,any ideas?
txblu
05-05-2004 09:36:35
 Re: 311 Baler knotter trouble in reply to link, 05-03-2004 16:29:10
If you guys need help on balers, try www.texastwistonline.com. This guy has baled over 1 million bales in his life and rebuilds/fixes/advses and all as a hobby.
I told him my 24T was shearing a flywheel pin on nearly every bale. He told me what to do, did it and hums like a Singer (sewingmachine guys).
Steve from New Holland
05-04-2004 16:57:48
JMS/MS has hit the nail on the head. I feel reasonably sure that the problem is "baling too tight". Steve
NHBalerman
05-03-2004 19:11:30
If the twine is breaking at the base of the knot try loosening the twine holder tension one flat at a time and also sharpen the twine knife or replacing it. NH offers a kit to replace the knife without buying the hold knife arm. Hope this helps.
JMS/MN
05-03-2004 18:12:34
You might also have the bale tension too tight, or baling under 'tough'- wet conditions. (Later in the day, when moisture builds up). Try backing off the tension cranks, after doing what Kelly says.
link
05-04-2004 19:04:45
 Re: Re: 311 Baler knotter trouble in reply to JMS/MN, 05-03-2004 18:12:34
thanks guys will try these things and let you know
Kelly C
05-03-2004 18:01:56
Acording to my Handy dandy trouble shooting book. It says .
" Twine frayed or broken 1/2 inch back of knot.
Rough edge or groove on knife arm throat.
Use a file or emery cloth to smooth rough areas. "
Kelly C
05-03-2004 17:56:53
IH
05-04-2004 07:30:46
 Re: Re: 311 Baler knotter trouble in reply to Kelly C, 05-03-2004 17:56:53
I think Kelly C has it right. I have a MF 12 that was doing the same thing and there were burrs on the twine arm that caused it.
Good Luck
