Need Knotter stack dimensions for NH68
Kelly C
05-01-2004 08:01:27
I am putting a new knotter on my NH68. The book I have has the dimensions for a 273 on up.
It gives a drawing of the knotter stack and dimensions for A, B, C and D. Mesurement C would be the most useful as Its the right knotter that I am replacing. Just putting it on leaves the Knotter not touching the mounting bracket.
If its the same as a 268 I could just go measure mine and make it the same.
Thanks
Steve from New Holland
05-03-2004 04:33:50
 Re: Need Knotter stack dimensions for NH68 in reply to Kelly C, 05-01-2004 08:01:27
Kelly, The 68 thru 273/276 balers all used a 7" knotter spacing. You can use dimensions from any of them. But only thing that really matters is to put a wear washer or maybe 2 just to the right of the RH knotter cam gear, and then space the 2 knotters seven inches apart. This will work out good for you. Steve
Kelly C
05-03-2004 17:49:49
 Re: Re: Need Knotter stack dimensions for NH68 in reply to Steve from New Holland, 05-03-2004 04:33:50
Thanks Steve. I should be able to get her up to speed now.
