Woods M-5 mower
Marshall Harris
04-30-2004 15:52:51
I am attempting to change out the cutting blades.
I removed the bolt and blade pin clip but cannot get the keyhole plate to budge. Any suggestions?
Thanks
BFarr
04-30-2004 16:53:14
 Re: Woods M-5 mower in reply to Marshall Harrison, 04-30-2004 15:52:51
If it has been awhile since this was done then it is likely that rust has set it. This plate has 1 or 2 shims between it and the beam. I would suggest plenty of Kroil, WD40 etc. Then with a flat pry bar you may be able to hammer it sideways. As soon as it moves any amount, it will start to loosen. Keep washing away the rust as it loosens, so that it doesn,t stick again part way. Let me know how it turns out.
