Need ideas - Sprayer
Errin OH
04-30-2004 08:54:52
I purchased a JD sprayer ($35) last fall. Nothing fancy just a 100 gal tank and about 20' booms. Works off PTO, and has selector switch for any combo of R, L, & Center sections. Tried it out yesterday with the NAA and it worked like a champ. Even got the math right first try (appilication per acre vs speed of travel, etc). At this point I have about $100 (mostly new nozzles) in it and don't see a point in buying a new markin system for a cheap sprayer. But I would like to come up with a way to mark where I've been. Any ideas?
Wes
05-01-2004 13:31:29
 Re: Need ideas - Sprayer in reply to Errin OH, 04-30-2004 08:54:52
Go to your local store and see if they have any of the tanks that pop comes in. If they don;t ask the supplier. If you take a used one and fill it with water and foam concentrate then all you need to do is find a way to force air into it and run a line out to the end of your boom. I have used cheap 12 volt compressors and they work good. Just use a 1/4 turn valve to regulate the foam.
Jerry D in NC
04-30-2004 20:03:25
Got a cheaper way by far. Get a cheap cane fishing pole. Now we in the south have an advantage because the bamboo that you use to make a fishing pole grows all over but you brethren of the north will have to make do. Measure how far the booms stick out from the tires and then tie the bamboo equal to that distance to the booms and hang a piece of flaging from it. Then when you drive, you let the flaging hang in the tire tracks of the previous pass and you have a perfect lap over.
kyhayman
04-30-2004 18:28:39
Ok, some folks may think I am crazy and I am sure I will offend some eco Nazis but..... ..... ..... ...
Get a roll of toilet paper and drop a sheet a intervals in the field. Just drop straight down and you will be able to tell where you have been if you cant see your wheel tracks.
First time it rains the toilet paper will melt and goes away. Learned it from my lime truck driver who asked me to mark sink holes this way.
Chris-es-ILL
04-30-2004 19:15:12
 Re: Re: Need ideas - Sprayer in reply to kyhayman, 04-30-2004 18:28:39
I know this reply will be OT, But....
I learned the same trick to track wounded deer. Many folks around here call me when they need help tracking. I carry a roll of TP in my fanny pack while hunting. When you look back at the trail of pieces of white TP you can see the path that the deer took, which points you in the right direction.
Now, back on topic, I would think that it would be hard to drop TP while driving a sprayer!
I have a foam marker {A-Mark} that I only used about twice {two years} before changing spraying programs {it now sets on a shelf}. Foam markers are relatively simple and I think a person could make his own.
Chris Brown
04-30-2004 16:56:59
Too bad you can't buy a gallon jug of red food coloring. I am in the same predicament as you. Last year I had 2 feet wide strips of burdocks in my soybeans where I missed. In a small straight field it is not hard to keep track of where you've been but in a big(10 acre or more) field I lose track of where I've been and either double shoot it or I miss it all together.
paul
04-30-2004 11:42:56
Marking? Just drive straight. :)
There are dyes you can add to the spray mix, cheap this time, but it does add up over the years.
Foam markers are common, if you search the ag places like www.farmshow.com you will probably find some made from shaving cream cans or the like, through full blown auto units costing over a grand.
--->Paul
INCase
04-30-2004 10:08:43
Ask your spray dealer. Many sprays (at least herbicides) can be applied with marking agents that disolve away w/time some sprayer are die compatable some are not.
greenbeanman
04-30-2004 09:48:09
I guess my thoughts for cheap marking would be to enlist the aid of a compressed air garden variety of sprayer. You probably already have one that could be adapted.
I would think that some watered down latex paint of a bright color would leave somewhat of a trail to follow. Kind of like the purchased markers that use a silver paint.
Operate a left or right boom end paint tip from the tractor seat. I envision a hose leading to each with a valve for right or left. You could set it up with solenoids and possibly a vehicle flasher to turn it on and off automatically.
You would have to pump up the sprayer from time to time, but I'm thinking it would be a cheap solution. You can probably just guage each swath from the previous tire tracks.
