Van Brunt Mounted Field Cultivator
Duane Welle
04-29-2004 09:05:45
I picked up a old A JD with a mounted Van Brunt 8' field cultivator. Does anyone know anything about this cultivator. Would like to know model number and get a manual for it.
Leroy
05-02-2004 09:09:53
 Re: Van Brunt Mounted Field Cultivator in reply to Duane Welle, 04-29-2004 09:05:45
Is it the 3 point hitch or the Lindeman Hitch?
Leroy
05-02-2004 18:34:30
 Re: Re: Van Brunt Mounted Field Cultivator in reply to Leroy, 05-02-2004 09:09:53
I should have added the 3 point hitch cultivator would have to be either the C7 or C10, would have to dig out my books, the lindeman hitch was john Deeres first atempt at rear mounted equipment
t4mike
05-02-2004 11:31:30
i don't know what lindeman hitch is, the no.8 cultivator set-up is actually attached to brackets just behind the front tires, it then uses the tractors hydraulics to lift and lower the rig at the rear end.
t4mike
05-01-2004 10:23:57
i've got a nice 8 page, black, white and green sales brochure that i'd sell. its for the no.8 field cultivator which is mounted. it has alot of info in it and would, i think work as a operators manual till you found one. i can email you scans of it if you want.
