CHEAPSKATE...BUT WILL IT WORK?
DAVID
04-29-2004 06:34:36
I bought an AC-B with a woods belly mower. The mower has two right-handed threaded spindles and a left-hand. I was mowing the other day and apparently the left-hand spindle blade came unbolted because of the direction it was spinning. I've priced a new spindle and it is rather expensive. My question to you guys is.. will a helicoil work if I bore it out and insert a righthand thread helicoil? Thanks in advance for your insight or alternate solutions:)
John *.?-!.* cub owner
04-29-2004 07:14:00
 Re: CHEAPSKATE...BUT WILL IT WORK? in reply to DAVID, 04-29-2004 06:34:36
try using the medium strength (blue) Loctite. It can still be removed, but should stop blade loosening.
David
04-30-2004 09:38:02
 Re: Re: CHEAPSKATE...BUT WILL IT WORK? in reply to John *.?-!.* cub owner, 04-29-2004 07:14:00
Thanks John. I will give that a try. That's a much easier solution to try.
John
04-30-2004 10:58:55
 Re: Re: Re: CHEAPSKATE...BUT WILL IT WORK? in reply to David, 04-30-2004 09:38:02
I would go to an industrial supply, they make bolts with a nylon insert to help prevent them from loosening up. Muck like the insert you find in lock nuts.
