Mowing horse hay with a cutditioner
Joe
04-28-2004 15:04:46
I'm going to go look at a New Idea 272 7' cutditioner tomorrow. What are some things to check? How good are these for mowing down hay that is to be used for horses? Reasonable price? Thanks!
Farmer Tom
04-29-2004 06:27:55
 Re: Mowing horse hay with a cutditioner in reply to Joe, 04-28-2004 15:04:46
I have a NH 279 - 9' cut. Works best with grasses rather than leafy materials, although it cuts both. Leaves a rough looking stubble after cutting, but the manual says that is good for regrowth. Can also be used as tedder. It's a simple machine with few moving parts, thus only needs simple maintenance. Make sure the gear box and drive belt are good, and the rotating flail drum bearings are okay. There is a special tool/wrench that should be stored under the drive line cover that is for the removal of the flail rods. The cupped knives can be sharpened and are still available, but 'pricey.'
The most important thing needed to operate it is HORSEPOWER! My 279 really works my JD3020, but the Oliver 1850 hardly knows its behind it.
One other thing, it will 'throw' things out the back and the front. Best not to have anyone working directly behind it or for that matter directly in front of it. All in all, I think it is a good machine; I like mine.
Farmer Tom
04-30-2004 05:29:45
 Re: Re: Mowing horse hay with a cutditioner in reply to Farmer Tom, 04-29-2004 06:27:55
Oooops! Made a mistake; it's a NI 279, not NH. sorry about that. Got confused, as I also have a NH 479 haybine. However, what I said about the NI 279 still stands.
Joe
04-29-2004 10:21:52
Thanks! Well, I bought it..gonna bring it home this weekend. I couldn't get it hooked to a tractor but everything looked good and tight. Saw some of the fields that were cut and the hay it made and they were pretty decent. The knives were still pretty sharp so we'll se how it does when it comes time to cut. Only fall back is it's a 7' i'da rather a 9' but hey it's only hay right? Power won't be a problem, don't think the ole 1755 diesel will even realize it's back there
