woods belly mower
Randy in Iowa
04-27-2004 17:07:19
I have broken one of the spindles that hold the blades on a L306 woods belly mower. Does anyone know how the shaft and bearings come out of the spindle so I can weld it?
Jesse M
04-28-2004 16:06:48
 Re: woods belly mower in reply to Randy in Iowa, 04-27-2004 17:07:19
The spindle shaft is pushed toward the blade side,you will probably need a press for this. If I remember correctly, you must remove the roll pin on the pulley side before doing this. The spindle case is either cast iron or cast steel, so it will probably need to be welded by a professional. It might be cheaper to just buy a new one, about $100.00 for a complete spindle assembly.
