Ajusting one bottom 3pt plow
Jim
04-25-2004 14:38:33
I have a howes mph112 one bottom 3pt plow. I want to use it on a to20 the wheels are narrowed up and the plow is ajusted all the way over but it still skips a spot between the furrows when i keep my rear tire in the furrow.Can anyone give me some good advice on how to fix this.
Bob Jarvis
04-28-2004 10:04:15
 Re: Ajusting one bottom 3pt plow in reply to Jim, 04-25-2004 14:38:33
With the plow on the tractor and with the plow resting on the ground, measure the distance from the inside edge of the right rear tire to the plow point. What is this distance? If I'm interpreting the model number of your plow correctly it looks to me like you've got a 12" single bottom plow, so the distance from the inside of your right rear tire to the plow point should be less than or equal to 12 inches. If it's any more you're probably going to leave an unplowed strip.
Another question: are you using stabilizer bars with your plow? If so, please take them off. Stabilizer bars are great for things like brush hogs but are not appropriate for tillage equipment. The sway chains on your lift arms (you have sway chains on your lower lift arms, right?) are sufficient to keep the implement from banging into your rear tires, and plows and other tillage equipment need to be free to "work" a bit from left to right as they move through the dirt.
Third: how deep are you plowing? With a 12 inch bottom you shouldn't be going deeper than 6 inches. Going too deep might conceivably push the plow and lower lift arms to the left (i.e. farther from the right rear wheel), thus leaving an unplowed strip. If you've got the plow nearly buried when you're plowing (as one of my friends and co-workers likes to brag that he does) you're plowing too deep. A plow is a tillage tool, not an excavator.
I hope this helps.
David Wilcox
04-28-2004 08:51:31
I can give you advice, if you try it, then you can tell me if its good or not. [email protected]
