Wagner loader
Jim(UT)
08-30-1999 21:12:31
Bought a Ford 850 tractor that came with a Wagner loader. Loader is not currently installed and I would like to remedy that. Mounting flange below the grille matches flange on loader. Problem is, the shaft connecting the crank pulley to the hyd pump is missing. I don't even know what it looks like. Does anyone still make parts for these rascals? Loader tag says the model is "FORD W3M" and sn is 3797. Tractor is a 1955, sn 57804
Rufus
09-05-1999 12:23:26
 Re: Wagner loader in reply to Jim(UT), 08-30-1999 21:12:31
Walt's Tractor Parts should have the parts you need. You can look at their on line catalog. If you never visited their site just click on the parts bar to your left on these pages. Good luck
Halbert09
08-31-1999 13:48:10
Original loader would have used a special crank pulley that had four holes with rubber inserts in them in a square pattern. Pump drive-shaft would have similar 4 prongs on end to fit into the rubber grommets (which allow for flexing). See if you have a good pulley; sometimes the pulleys were ruined by not replacing the rubbers when worn, or letting the pulley get loose. This kind of pulley was also used on other front pumps for sickle bar mowers etc. I'm sure some other people on this site can advise you where to get this stuff. Good luck.
bandit
07-22-2001 18:19:46
 Re: Re: Wagner loader in reply to Halbert09, 08-31-1999 13:48:10
I have been able to find all the required parts that Jim is talking about at my local Ford tractor dealership. The owner/employees are very helpfull. The only thing I have not been able to find is a part number for the Vickers pump. Can anyone out there help me out???
