Jacobsen B-40 PTO DEbris Blower...PTO Shaft ?
Paul
04-24-2004 07:03:45
third party image
I recently purchased a used Jacobsen B40 PTO Debris Blower. It has an unshielded PTO shaft and I want to change it to a new shielded shaft.
The problem is that I can't seem to figure out how to remove the old PTO Shaft. There seemed to be a center pin, but there was'nt and I can't seem to figure this out. I am a bit new to tractors and implements so any help you can provide would be appreciated. I included a picture of my dilema. Thanks!
evielboweviel
04-25-2004 09:25:23
 Re: Jacobsen B-40 PTO DEbris Blower...PTO Shaft ? in reply to Paul, 04-24-2004 07:03:45
once the driftpin is removed it should come off. Odds are that it is rusted on the shaft. you will need to split the ujoint and use a puller to remove the ujoint half on the shaft
Good luck
Ron
