Disk controll thingie?
Bill Drew
04-24-2004 06:06:06
third party image
Got a disk with my Ford 2N and don't know what the lever sticking out of the angle setter does. Looks like there should be a rope connected to it to pull from the tractor.
There is a bit of green paint under some of the rust so I suspect it is a JD.
nwb
04-24-2004 15:08:35
 Re: Disk controll thingie? in reply to Bill Drew, 04-24-2004 06:06:06
Post this on the Case board. I'm pretty sure this is a Case disc. Look for an eagle on that clutch housing.
Mguy
04-24-2004 15:06:39
Bill, that there's a JI Case disk. Mguy.
Bill Drew
04-24-2004 17:49:29
 Re: Re: Disk controll thingie? in reply to Mguy, 04-24-2004 15:06:39
Thanks for the ID - will go search out what I can find out about it.
Norm
04-24-2004 07:10:27
What does the lever do when you move it?
Bill Drew
04-24-2004 11:21:45
 Re: Re: Disk controll thingie? in reply to Norm, 04-24-2004 07:10:27
Hooked it up with a rope to the lever and figured it out. When the rope is pulled, the crank turns moving a control rod back and forth. (Added some red arrows to the picture to show that motion motion). Just let go of it when it gets to the place where you want it.
