Will my jubilee pull 16 inch 2 bottom plow?
jay
04-23-2004 16:50:28
Will my jubilee pull a set of allis chalmers 16" two bottom plows? Will i need to put some weight on the front. My neighbor has a set he will sell me for 50$. From what i understand the plow depth should be set 8"s deep for 16" plows. Could i just set them a few inches shallower? I am a first timer so any suggestions would be of great help. Thanks Jay
chris mf135
04-25-2004 15:52:23
 Re: Will my jubilee pull 16 inch 2 bottom plow? in reply to jay, 04-23-2004 16:50:28
can always take off rear plow, i did it on a set of ih plow chief and it worked great. i like to plow deep and don't have fluid in my tires.
treeboy
04-25-2004 04:48:56
i pull a john deere 2-16 with mine, 1st gear... 6 to 7 inches deep,, i have the cover board att. also & this helps to complete the turn over of the soil.... If your then disk try to go in the same dirrection as plowing for the first disking.
Blvd
04-24-2004 16:58:48
Jay, where are you located? Will pay a finders fee for that plow. Thanks Herd0nBlvd~aol.com
nwb
04-23-2004 17:53:48
If you were talking about a Ford 101 plow I would say definately yes. Different plows pull different. Is the AC plow pull type or 3pt?If it is pull type you'll probably need rear weight. If it is 3 pt. you can pull it if it is scoured and adjusted properly. AC also made snap coupler plows and you can't use one of these. If it is 3 pt. get someone who understands 3pt. plows to help you adjust it. There is kind of a knack to it.
