setting offset disk gangs. also terraces
Jim Luckie
04-23-2004 08:58:52
I have a 12' miller offset disk and was wondering where or how to set the adjustable gangs. I am disking under quite a bit of winter grass and cheat grass to sow feed (haygrazer) and it clumps pretty bad on the first pass. also tips on working a terrace with an offset disk would be greatly appreciated
JMS/MN
04-23-2004 22:35:34
 Re: setting offset disk gangs. also terraces in reply to Jim Luckie, 04-23-2004 08:58:52
An offset may or may not be a primary tillage tool, depending on weight and blade size. Did you try making two passes with it? I just bought a White 281 this year, and in sod it does fine with two passes.
thurlow
04-23-2004 16:42:27
"Clumping" is going to be a problem with an off-set (or any cutting.....as opposed to pulverizing) disk when working turf. We are talking primary tillage here; just have to continue to work it with some secondary tillage tool.....disk, field cultivator, do-all, etc. As far as the terraces, I'd just try not to work them down any more than I could help; locally, we re-do them with a breaking plow every year or two..... .
Joel Harman
04-23-2004 14:45:56
Might try hitting it with springtooth harrow first.
