Adding 3 Point Hitch
Mike
04-23-2004 07:22:20
Hello,
Would it be safe to add a home made 3 point hitch to an old IH Super C. I would like to use the mid mount cultivator lift hydraulics to operate the lift with extension rods. The aftermarker lifts that I have seen all have separate hydraulic cylinders for operation of the lift. I would like to get away as cheap as I can and remain safe. Any comments appreciated, including negative ones.
Thanks,
Mike
Leroy
05-02-2004 10:01:04
 Re: Adding 3 Point Hitch in reply to Mike, 04-23-2004 07:22:20
I would say it would work but not with the lift capacity the cylinders would have, grader blade OK, heavy load Not.
old
04-23-2004 09:24:03
Saw one set up that way the other day at a tractor dealers yard. It had 2 bars that ran up front to use the lift that was on it looked pretty good
