Kelly C around these parts found some decals - on ebay I believe. Might want to do a search here or watch for him, he might have some advise. For my side rake, I buy metal rake teeth from Runnings. Pretty good, about a buck each. I got some of the 69 cent teeth from TSC. They are not hardened, twist up into a pretzel. Yuk. Worthless. Now, these stores change their suppliers regularly. I suggest you shop around, buy a few, see what works & what doesn't. There is _certainly_ a difference in quality. I have 3 different colors of teeth on my rake, all work fine. Don't think any of those TSC cheapies lasted a year tho. The hardened ones like to break - brittle. But the soft ones bend - that's really worthless. I suppose the OEM teeth would be better, but I rake a lot of uneven ditchbank & rough fields (straw) which is going to break 10-20 teeth a year no matter what I put on. I have no experience with the rubber teeth, but I hear most OEM have a joint under the rubber, and the cheapies you can find do not. And this does make a difference. --->Paul
