How to protect wood handles
smirkey
04-22-2004 13:36:49
i just replaced the handles on my potato plow. they came untreated. i don't really want to paint them. should i linseed oil or something?
Fern(Mi)
04-23-2004 17:42:26
 Re: How to protect wood handles in reply to smirkey, 04-22-2004 13:36:49
Boiled linseed oil should do trick. Problems with paints and varnishs they hold moisture. With the linseed oil there is no hardened surface for moisture to become trapped behind to split or blister to get out from. If neccasary redo every so often. Oil will soak into oil. lay on varnish or paint.
My thinkinking, my practice.
Fernan
Ben in KY
04-23-2004 08:52:08
The boiled linseed oil works better than the raw oil.
greenbeanman
04-22-2004 17:11:57
I would either use linseed oil or marine spar varnish. If always stored inside they really don't need much.
Nebraska Cowman
04-22-2004 15:54:56
i like linseed oil. On exposed wood on boats they use teek oil. i think it is somekind of mixture containing linseed but don't know what else. You should be able to buy it at the marina.
