Woods RM 306
Mike S.
04-20-2004 17:13:37
I just bought a used woods 3pt finish mower, I believe it is an older model, not sure how to date it. Has rear wheels and chains that support the front to keep from scalping. It has 3 blades. The center bearing went out and I am trying to remove the pulley to change the bearings and or bearing housing. Any suggestions on how to remove the pulley, and change the bearings. The Threads in the bolt holes that should remove the pulley are stripped out. I have tried to use a gear puller but I fear I am applying enough pressure to break the pully.
thanx
Mike S.
