Hydraulic Problems
Bill Grumbine
04-17-2004 10:36:34
Howdy everyone. I have a John Deere 400 garden tractor with a front end loader on it. I needed to add some hydraulic fluid, so I bought universal hydraulic fluid at our local Tractor Supply and added it to the existing fluid in the loader. There are no marks of any sort on this thing as to manufacturer, or anything else.
Anyway, the loader worked fine for a while, but that last time I had it out, it would barely move, and when it did, it was jerky, and it won't hold or move much weight. Additionally, it bounces as I drive along, as if the cylinders were spongy.
If anyone has any ideas on what is wrong and how to fix it, I would really appreciate hearing about them.
Thanks.
Bill
Bill Grumbine
04-17-2004 17:27:58
 Re: Hydraulic Problems in reply to Bill Grumbine, 04-17-2004 10:36:34
Thanks for the quick reply Paul. I guess I have some repair work ahead of me.
Bill
Paul Janke
04-17-2004 13:55:16
All of your symptoms indicate air in the system. The most common cause is a low fluid level. Tied for second thing to check for is a leaking seal at the pump shaft or a hose in the pump suction line which is collapsing, sometimes only an inside layer. Another source of trouble is a leak in the suction line between the reservoir and pump.
