bush hog castle nut 70694 what size is this nut?
dan ny
04-15-2004 16:21:09
I have a bush hog sq72 that i had to split the nut that holds the blade assembly on. called a local bush hog dealer and he said parts on the older models are not available and to go to a hardware store that sold nuts but i cant find the size of the nut even on the bush hog web site thanks for helping dan
dan ny
04-16-2004 18:07:44
 Re: bush hog castle nut 70694 what size is this nu in reply to dan ny, 04-15-2004 16:21:09
well after two days of hunting and an email to bush hog international i got the size and located a dealer out of the five we have in the area that had one in stock it is a metric nut m24-2 go figger thanks for the help
dan
Indydirtfarmer
04-16-2004 14:58:38
Now don't get me wrong, I'm NOT a Tractor Supply Co. fan by any stretch, but I was looking through their "Blue Book" today. (Their catalogue) Under the Brush cutter parts list, they had Bush Hog parts. It listed several blades, a bolt, and a nut. It MIGHT be the one you're looking for. John
greg
04-16-2004 07:13:46
if you dont already have one, buy a cheap calipers...dial ones are less than $20 and very useful. measure the outside diameter of the spindle. then, either count how many threads there are in one inch of the spindle, or use a pitch gage. example, a 1/2-20 nut is 1/2 inch diameter, with 20 threads per inch. any hardware supplier should be able to get you what you need, and having these tools will prevent this in the future. im sure this is not metric.
Try
04-15-2004 19:45:31
Call (859) 865-2205, Cocanougher Farm Equip. near Harrodsburg, KY. They have a couple of the sharpest parts people around and are a Bush Hog dealer. Have your model # and serial # handy. They 'may' have one in stock or can tell you the size. Open Sat 'til 1200PM.
Norm
04-15-2004 16:56:48
Unless I'm missing something, just measure the diameter of the bolt/shaft.
dan ny
04-15-2004 18:02:17
 Re: Re: bush hog castle nut 70694 what size is thi in reply to Norm, 04-15-2004 16:56:48
i don't know if its SAE or metric
Norm
04-16-2004 05:44:47
 Re: Re: Re: bush hog castle nut 70694 what size is in reply to dan ny , 04-15-2004 18:02:17
Major problem, get both, probably $.29 each.
