little genius plows
darren
04-15-2004 15:28:11
i've got a set of two bottom little genius plow's with a tail wheel, i pull them with my farmall H. i was trying to plow tonight but i couldn't get it to be consistant. in one part of the field it digs down probably 8" and flips the sod great in others it digs down 14" and get's me stuck, in others it doesn't even cut in, the soil type is all the same. i've never had this sort of trouble before, so...what do i need to adjust on the plow's or tractor, i can't see there being any adjustment in it other than the hitch. any help is truely appreciated.
Josh
04-16-2004 19:27:12
 Re: little genius plows in reply to darren, 04-15-2004 15:28:11
Darren,
I have had bad plow shears (points)and that would keep the plow from cutting into the ground. I have never had it go the other way though. Just a guess here, but could the linkage between your depth adjustment levers, and the axles be broken? That would let the plow do its own thing. I hope this helps you. Josh
