Baler help
Rich
04-15-2004 12:16:50
I have about 20 acres of hay field. I am looking for a good used baler but I really don�t know anything about them. I have a 4WD MF compact tractor, 33 HP. There are three balers advertised locally:
MF 120 baler
NH 310 baler
International model 37
Would any of these work for me? Which is best? Thanks!
JustRight
04-19-2004 14:43:21
 Re: Baler help in reply to Rich, 04-15-2004 12:16:50
I'd go with the NH. Keep away from the IH
Jim.UT
04-16-2004 19:57:02
I'm not familiar with a MF 120 but I have a MF 124. You're doing the right thing by researching before buying. I didn't and paid too much for my baler. I've seen the same baler sell for around $400 at least 3 different times. I paid....uh...more.
However, it's worked for me. The knotter system is a little different than what is typically found on New Holland or John Deere balers. Not everyone here is familiar with it and it made for some interesting Q&A here when I had knotter problems. But I had a good manual and was able to figure it out. Parts for MF balers are hard to find used and very expensive new. I'll continue to use it since it works and it's what I have. But knowing what I know now, if I were buying a first time baler again, I'd look for a well maintained JD or NH.
Dave H (MI)
04-15-2004 16:12:19
I don't know what your budget is, but JD made a heck of nice baler in the 24T. NH also has their hayliners. Someone could help me out on this but I think the numbers are liker 273 or close. 24T above can be bought in good shape for less than $1000. They are common and most parts are available from JD including manuals. Good starter machine if nothing else. Hope this helps.
20 acres can be a pleasant few days work if the weather is right.
txblu
04-16-2004 09:24:58
 Re: Re: Baler help in reply to Dave H (MI), 04-15-2004 16:12:19
I have a 24T green and the previous owner knew what a grease gun was and knew how and when to use it. Makes a profound difference on old iron. I'm in my 3rd season with it and paid $700 for it at an auction place but it was on consignment and I could buy it not bid on it.
It uses square bale twine (thicker than round bailer poly) and seldom if ever misses a knot. The flywheel has a 1/4" grade 8 bolt for a shear pin and mine likes to shear them if I don't play by the rules. Gotta get the windrow, moisture, ground and PTO speeds just right. The green dealer has the bolts and lock nuts.
On smaller tractors, when I get it humpin' it rocks my blue 3000 back and forth to the point of falling asleep and out of the seat. Larger tractors are not as noticeable. The 3000 is about the hp of yours and handles the workload just fine.
The problem with twine is varmits eat it and bust your bale in the barn. It's easier to handle than wire and you can see it better and there is less chance of a safety problem than you have with pieces of bailing wire lying out in the pasture (mowing, animal hazard).
txbl
paul
04-15-2004 23:44:22
Both JD & NH balers are very good, going back to the '60s. Other brands didn't figure out knotters quite as well, and thus were less popular, & less of them still around, & less parts now.
Get a good one.
Check with your tractor manufacturer - many compacts are too light or have weaker pto systems & are not reccommended or covered under warrenty for baling. That flywheel on a baler stores a good 50 hp, and a weaker power train can be damaged. But you have a pretty large compact, so should work if you don't get too much weight behind you.
-->Paul
Hay Dr
04-15-2004 15:18:16
ALL of these balers will work for you. The 310 is likely the newest model.
