Broke Disc
Hurk
04-13-2004 19:25:55
Last weekend we had good weather for getting field worked up. My brother in law ran the 8n with DISK
Dearborn
MODEL..... ..... ..... ..LIFT-E
SERIAL..... ..... ..... .464I4
20-DISK
some stumps had not rotten and they broke 5 of the disc. I can not find the right ones. They have a 7/8" hole and are around 15-1/2". Does anybody know where to find that size? Thank You.
Jerry D in NC
04-14-2004 11:59:28
 Re: Broke Disc in reply to Hurk, 04-13-2004 19:25:55
Again I have no affiliation other than I spend my hard earned dollars there but Agri-Supply has them and will ship them UPS. I don't know if your disk took 16's or 18's but I am sure that someone here on this form would have that info. Agri has the 7/8's in both
paul
04-14-2004 06:46:29
Shoup deals with a lot of replacement disk parts if there is no oem supply.
You most likely will need to replace a whole gang, very hard to match up new blades with old worn blades & get good results. Even a 1/2" difference on the same gang makes a ridger, not a disk.
--->Paul
Hurk
04-14-2004 07:42:56
 Re: Re: Broke Disc in reply to paul, 04-14-2004 06:46:29
Thanks Paul,
I had thought about some wear on the disc but not the match up being a problem, you are right. At all the places I have looked none have the 7/8" hole, I'll have to keep searching. Thanks again.
paul
04-14-2004 12:10:41
 Re: Re: Re: Broke Disc in reply to Hurk, 04-14-2004 07:42:56
sh oupp arts.com has 1 in their catalog with a 7/8" square hole. Sorry for the spaces, but seems web links often get edited out on me.
--->Paul
