Indydirtfarmer
04-12-2004 03:31:06
Re: JD 10' - 12' disc, can I pull it? help me Ind in reply to Rick K., 04-11-2004 18:52:03
EXPERT? Well, I'm honored, but I'm not so sure about the expert thing. What I do know about is John Deere's disc measurements. They would consider that a 12'-6" disc. Their size rating is always the width of the REAR gangs. (The widest point) That disc would be a little much to pull in plowed ground, with 45 HP. You are lacking in horsepower AND wieght. You could pull it on untilled ground, provided it's not cutting too deep. I'd say your tractor is more suited for something around 8'. There's a number of things that might effect the "outcome". Disc spacing is one. 7-1-2" spacing would keep the "pounds per disc" # down somewhat. It won't cut as deep, but is a better "finishing disc". 9" or even 11" spacing makes for a better primary tillage disc, but they tend to cut deep, making them pull harder. Wieght of the disc has a lot to do with how they pull. Newer disc's, made in the last few years, tend to be heavier. Higher horsepower tractors are more plentiful nowdays. The disc's are made for them. Just for comparison, I have a 60 HP, 7400 lb, 2440 Deere. I pull a 10'-6" disc with it (normally) I have a 12'-9" disc, with 9" spacing. It pulls like the anchor is out, behind the 2440. The 10'-6" has 7-1/2" spacing. It pulls fairly easy. I try to run at 5 MPH or above. The 12'-9" disc is used for shredding stalks, prior to seeding wheat. I have an old 4020. We pulled a 15' disc with it, back in the day. John
