John Deere Model B grain drill problem
RB
04-11-2004 16:56:13
The wheel bearing assembly on one of my grain drill wheel hubs lost out yesterday as I was sowing sudan. Does anyone out there have a parts manual with a picture of this hub and related parts that they could post on this site? If posting is not possible, how about posting the required parts needed to fix this problem. Thanks for any and all helpful comments.
Tom
04-12-2004 05:53:12
 Re: John Deere Model B grain drill problem in reply to RB, 04-11-2004 16:56:13
Get the exact Model and Serial Number off the plate and your JD dealer can get the parts for you. Also you can order you a parts manual and an operator manual thru JD.
txblu
04-12-2004 05:35:23
Have you tried your local green dealer. In my area, they have a comprehensive support program for old Iron. Needed a fuel cap and fuel tank inlet interconnect hose for a '60's vintage tractor. The cap was in stock, the hose was there the following day.
txblu
txblu
04-12-2004 05:37:52
 Re: Re: John Deere Model B grain drill problem in reply to txblu, 04-12-2004 05:35:23
I have a green drill also. Needed several nuts for the cutter blades (where you add grease). This thing is at least '60's vintage, paint gone, galvanized hopper almost worn thru.
Had em in stock. Plus they have the parts breakdown which they will print out for you and you can see the whole thing.
txblu
