Tires Size on JD 55ABH Moldboard
TractorNut
04-10-2004 18:03:40
Does anyone know the best 16" tire size on a JD 55ABH Moldboard Plow. Some of these came out with 15" rims and some w/ 16". Mine has the 16 inch. I believe the land side is larger than the furrow side. Thanks for any info...
mile0001
04-11-2004 10:19:43
 Re: Tires Size on JD 55ABH Moldboard in reply to TractorNut, 04-10-2004 18:03:40
Flipping through my manual for the 55ABH shows that for the 55H (hydraulic lift) the tires were both the same, taking a 5.50x16" tire. For the clutch lift, the furrow wheel was also a 5.50x16", but the land wheel was a 5x21" Power Implement Tire and Tube. The rear one for both was a 4:00x12.
The manual I have is probably from the late 40's early 50's, not sure if it was revised later on.
Andrew
