Took 4 Teeth off Both Spreader Sprockets
Wayne M Kittler
04-09-2004 19:45:26
Thank you Nebraska_cowman for the valuable reply below.
I bought an AC 180 spreader with a new chain and both rear sprockets missing 4 consequecutive teeth. What could have slawed these teeth ?
The shaft may need replacing unless the bearing points can be turned down and then built up. Is there a way to put a round bushing midway down a shaft so that it will bring that spot back to shaft circumference. This is not a keyed area. It will fit into the babbited bearing.
