J.D. FB drill seed tubes
rcrc
04-09-2004 07:51:59
I am looking for rubber seed tubes with ribs for a van brunt fb drill. They are pricy at the dealer and this is an experiment. Thanks.
jim
04-09-2004 11:06:12
 Re: J.D. FB drill seed tubes in reply to rcrc, 04-09-2004 07:51:59
TSC Stores also carry generic rubber tubes.
Tim(nj)
04-09-2004 10:59:58
Double disk boots or single disk boots?
What is pricey, exactly? A generic tube will cost $7.49. To put rubber tubes in a single disk FB drill, you also need an adapter bracket to clamp to the boot. That may come with the tube as a kit from the dealer, which could explain the cost. (I put them on my FB several years ago, but I don't remember if everything was sold as a kit, or separate).
rcrc
04-10-2004 04:09:01
 Re: Re: J.D. FB drill seed tubes in reply to Tim(nj), 04-09-2004 10:59:58
This drill has already been converted. The seed tubes alone from my dealer are 10+ each.As I posted, this is an experiment, and I don't want to spend any more than I have to.
MacSC
04-12-2004 10:08:16
 Re: Re: Re: J.D. FB drill seed tubes in reply to rcrc, 04-10-2004 04:09:01
If it's an experiment, then experiment with the tubes also. I made some temporary tubes for a planter I was trying to get into working order by using an old vacuum cleaner hose. Then another time I used a pool vacuum hose to do some fertilizer tubes on a planter that lasted for years.
