Setting up a Little Wonder Plow
Chris(WA)
04-09-2004 04:59:32
I am getting a Little Wonder 2-14 back into shape to plow this spring. Replaced the missing lift assist spring. Wanted to know how much tension to put on this spring. Thanks!
Bob-Wyo
04-09-2004 08:02:53
 Re: Setting up a Little Wonder Plow in reply to Chris(WA), 04-09-2004 04:59:32
Chris, not much of a plow man here, (flatlanders used one ways. lol)
Just set up a 3-14 New Genious, should be about the same.
Best way to start with, plow should lower and raise easy with levers, mine now can be worked with one hand, also
To tight--trip wheel will slid when lowering
To loose--trip wheel will slid when raising
this by my IH plow book.
Hope this helps you some to get started till the real plow guys get here, hitch height also affects
trip wheel and plow operation.
Bob
