Massey furguson model 57 4 bottom reversible plow
Bill-TX
04-06-2004 13:15:09
Hi all -
I just recently bought a massey model 57 reversible 4 bottom plow. The plow has spring trip bottoms and unfortunately after my first pass I hit a old buried wooden fence post and tripped the first bottom -- How do I reset this? -- I put the bottom back in the slot by rolling backwards and it went right in, started another pass and once it dug in a bit it tripped again this time without hitting anything.. are there shear pins that I need to replace?, or is there a reset sequence I need to do.. I did not get a manual with it so I'm flying blind any help would be appreciated
Thanks in advance
Bill
Tim(nj)
04-09-2004 14:10:09
 Re: Massey furguson model 57 4 bottom reversible p in reply to Bill-TX, 04-06-2004 13:15:09
There's probably a roller in there somewhere that may not be going back in its slot. My IH plow has a setup like that. It hadn't been used in 10 years, left outside, and the rollers were stuck. First couple times I tripped out on rocks, the bottoms wouldn't stay in after being reset. I ended up dropping the bottoms out of the standards and cleaning the rust out of everything and getting stuff moving like it was supposed to move.
Bill -TX
04-09-2004 23:21:38
 Re: Re: Massey furguson model 57 4 bottom reversib in reply to Tim(nj), 04-09-2004 14:10:09
Thanks for the reply -- there is rollers inside so I will blow it all out and check thanks for the help I was beginning to think I was the only one with this problem LOL
take care
Bill
