Wood preservative for wagons?
Josh
04-06-2004 06:26:27
What do you guys use to protect wagons that are left outside? I have heard of using used motor oil, but i have also heard that over time it is worse than just leaving them uncoated. Any other cheap wood preservatives? Thanks.
JD-A
04-06-2004 07:13:43
 Re: Wood preservative for wagons? in reply to Josh, 04-06-2004 06:26:27
Boiled linseed oil will work, and will bring the natural color out. It will have to be reapplied like paint to give continuous protaction.
JD-A
04-06-2004 07:30:12
 Re: Re: Wood preservative for wagons? in reply to JD-A, 04-06-2004 07:13:43
Heat the oil on a burner then brush it on this lets it penetrate deeper into the wood fibers.To get a little better protection it probably needs 5 to 8 coats, depending on where you live. Give the oil time to oxidize. Direct sunlight will heat this oil and cause it to ooze out of the surface,a coat of paint over this seems to help it last longer.
