Grain seed weight per bushel??
Doug D
04-05-2004 11:16:18
How much does a bushel of winter wheat, winter oats, and winter rye seed weigh? Trying to figure out seed quanities needed for pounds per acre seeding rates. thanks, Doug
Leroy
04-05-2004 19:53:01
 Re: Grain seed weight per bushel?? in reply to Doug D, 04-05-2004 11:16:18
The legal weight for oats here in Ohio is 34# with good cleaned seed oats hiting up to 40# per bu. that would have come off the combine at 32# with the cleanings making the difference, only way to know is a test weight scale.
paul
04-05-2004 18:38:28
What is winter oats, never heard of it?
Typically here in Minnesota we plant 3 bu an acre oats, 2 bu an acre wheat or rye, if that helps.
--->Paul
JMS/MN
04-05-2004 21:29:36
 Re: Re: Grain seed weight per bushel?? in reply to paul, 04-05-2004 18:38:28
I was wondering that too- are they trying to keep that a secret from those of us who know what winter is, or what?
kyhayman
04-05-2004 19:33:03
Around here we have winter oats (or oats) and spring oats. Winter oats are seeded in the fall (treat just like wheat or rye). They are a little more prone to winter kill here than the other small grains but are the preferred oat (yields 3:1 over spring, due to tillering)
Gary in MOzarks
04-05-2004 22:01:48
 Re: Re: Re: Grain seed weight per bushel?? in reply to kyhayman, 04-05-2004 19:33:03
Where would a person buy winter oats? (this isn;t a left hand monkey wrench thing is it?) Down here in the land of wimpy winters, (moved here from Michigan)wet wet springs would make planting in the fall a nice idea.
kyhayman
04-06-2004 03:46:13
 Re: Re: Re: Re: Grain seed weight per bushel?? in reply to Gary in MOzarks , 04-05-2004 22:01:48
I get them at my local Southern States Co-op. Any of your local feed and seed stores should have them.
norebert kanzler
04-05-2004 16:29:54
rye = 56 # per bushel
oats 32
wheat 60
David from Kansas
04-05-2004 12:13:30
Doug,
winter wheat is 60#, oats is 32#, I think rye is also 60# but not sure.
Dick Davis
04-07-2004 04:41:07
 Re: Re: Grain seed weight per bushel?? in reply to David from Kansas, 04-05-2004 12:13:30
David now that you have all the numbers, be advised that around here no seed is sold by the bushel! Most comes in 50# bags, so how many bushels are there in 10 sacks of oats? It's never easy. My nickel Dick Davis
