towner disc
stan
04-03-2004 08:05:04
Is there a source for bearings for the Towner discs?
JMS/MN
04-03-2004 11:43:06
 Re: towner disc in reply to stan, 04-03-2004 08:05:04
Unless they are totally shot, you should be able to find a mfr number printed or stamped on them. Can either match to mfr or generic equivalent. Dealers have cross reference lists.
Ol Chief
04-03-2004 14:26:50
 Re: Re: towner disc in reply to JMS/MN, 04-03-2004 11:43:06
I am interested to find that someone else is asking this question.I own a 14 foot Towner offset with 24 inch blades. The finest disc that I have ever used.Unfortunately it is not a hydraulic transport model.Last year my helper ran it with a bad bearing so long that the housing and bearing shields were destroyed,I checked on the net and found Towner Mfg.Co.Located in Calif. but could not raise them nor any agent.In final dispair I wound up machining a new bearing housing and shield plates myself from bar stock. I made a drawing of the new assembly but think it was lost when I moved to my new farm.I also mfg.a couple of spare nuts for future.Do not know what you have but will try to help if you wish to call me.Ph #1 830 997 8296. By the way bearings are standard and should be a shelf item at any bearing supply house if can give them a number.Good luck, John Cooney
