Tim{NJ}
Hunter
04-01-2004 09:27:50
Tim I need some help. Wanting to plant lespedeza @ the rate of 30 pounds per acre. Where do I need to set my drill It is the Van Brunt mobel B, I can't read my chart. Thanks! Hunter
Tim(nj)
04-01-2004 18:59:01
 Re: Tim{NJ} in reply to Hunter, 04-01-2004 09:27:50
Are you attempting to use the grain box, or the grass seed box (if you have one)?
The chart is in the drill, which is in the Morton building 1/4 mile down the road. Will look at settings tomorrow. If I recall, alfalfa and lespedeza settings are very close.
Hunter
04-02-2004 06:07:31
 Re: Re: Tim{NJ} in reply to Tim(nj), 04-01-2004 18:59:01
Tim I'll be using the grain box, don't have the grass seeder box. I really would appreciate you checking for me. Hunter
Tim(nj)
04-02-2004 13:18:21
 Re: Re: Re: Tim{NJ} in reply to Hunter, 04-02-2004 06:07:31
Notch 16 on indicator will give you 33 lbs. per acre. Make sure the little doors in the bottoms of the feedcups are latched in the slot closest to the shaft.
