Pros and cons of 8 wheel caddy type hay rake
Steve
11-15-1998 09:21:13
I think i want a v rake like this i now have a
Kuhn rotary rake and a NH side deliverly but the
caddy would be much faster i like that idea!!
I found a Gehl used for 1800$ but have been told
i will not like it because it has 2 hydrl. cylinders verses 1 on the newer types some says
they raise it up before they turn around and some
say they leave it down they also say with 2 cylinders it takes a bit longer to raise because
you haft to bottom the first cylinder before the
second one operates this would make it time
comsuming if you raised it each time
please help with opinions
Murph
11-15-1998 18:41:18
 Re: pros and cons of 8 wheel caddy type hay rake in reply to Steve, 11-15-1998 09:21:13
: I think i want a v rake like this i now have a
: Kuhn rotary rake and a NH side deliverly but the
: caddy would be much faster i like that idea!!
: I found a Gehl used for 1800$ but have been told
: i will not like it because it has 2 hydrl. cylinders verses 1 on the newer types some says
: they raise it up before they turn around and some
: say they leave it down they also say with 2 cylinders it takes a bit longer to raise because
: you haft to bottom the first cylinder before the
: second one operates this would make it time
: comsuming if you raised it each time
: please help with opinions
