detachable Chain
John Humphrey M
03-31-2004 22:01:56
I have to ID some chain. Links are 1 3/4" from center to center, 1" inside width, 1 5/8" outside width. Thanks to any one that can help.
John Humphrey Morocco IN.
04-01-2004 10:45:18
 Re: detachable Chain in reply to John Humphrey Morocco IN., 03-31-2004 22:01:56
Fired up the sand blast cabinet and found a #62 and a star. Thanks to everyone for the help;John Humphrey
Bob
04-01-2004 07:49:54
Email me if you'd like me to email you a copy of a detachable chain ID chart.
trrjohn
08-12-2004 17:37:12
 Re: Re: detachable Chain in reply to Bob, 04-01-2004 07:49:54
I have restored an old IHC / Farmall pull type, ground driven, manure spreader (circa 1935) and need several chain links to complete the apron portion of the project.
Chain links are approximately 2" wide, OAL is ~3.25", pitch is approx ~2.9" Center square holes are approx. 1.1" wide x 2" long Rolled clevis portion is approx 1.06" wide x ~1" OD Appears to be about 4.1 to 4.2 links per foot
I cannot find any detachable chain link specifications or standard size, so cannot determine the correct part number.
Might you have chain links or detachable chain link standard sizes to help me complete my project? Or could you suggest a source for replacement links?
Thanks in advance for your assistance.
Regards,
John
Steve from New Holland
04-01-2004 04:33:25
John, I believe the chain you have is #62 steel detachable chain. Steve
Ted
03-31-2004 22:58:39
Not sure about how you discribe inside width and outside width. But a roller chain with center to center of 1 3/4" would be 140 ANSI pitch. Your outside width seems off. Inside at 1" is standard for 140. If you have standard 140 your outside should be 2.14" at the widest part (the pin on a standard, non-connecting link). Hope this helps, Ted
paul
04-01-2004 00:26:17
 Re: Re: detachable Chain in reply to Ted, 03-31-2004 22:58:39
Probably not, you're talking roller chain, he's talking flat chain?
All the flat chain I've seen has the number stamped into it, wet a finger & run around a few links, you should find a 51 or 55 or some such number.
Or, take a link to a farm supply store & compare to what's on the shelf - some one or some dealer in your area should handle it.
---->Paul
paul
04-03-2004 21:47:28
 Re: Re: Re: detachable Chain in reply to paul, 04-01-2004 00:26:17
Think I came across kinda rude there Ted, as I look at what I wrote. Don't know why my brain picked out that path of words. Sorry. Not the way I was thinking.
--->Paul
