John Deere 14T Baler and New Holland 477 Haybine
Ryan Pierce
03-30-2004 15:33:14
I found a JD 14T Baler and a NH 477 haybine for sale in my area(NW Indiana). They have both been taken good care of and been well maintained. I'm gonna bale around 15 acres of alfalfa, 15 of grass, and 45 of straw. Do any of you guys think the baler will have a problem with that kinda volume? Plus, will 30 acres of hay be too much for the haybine? Thanks!
Leroy
04-02-2004 05:45:19
 Re: John Deere 14T Baler and New Holland 477 Haybi in reply to Ryan Pierce, 03-30-2004 15:33:14
That haybine is the corect size for that baler and they would do over a hundred acres of hay a year, for the straw from the big combines be sure they have a straw spreader on to spread the big row then rake with your rake that is sized the same as the haybine
old
03-30-2004 20:56:55
A 14T is a good baler but remember its almost 50 years old so you need to go slow and watch what its doing it likes winrows that aren't big or small just some where in the middle
Josh
03-30-2004 18:02:17
I have a 14t. I really like it, it pulls easy, runs quiet, is easy to work on, and almost never misses a bale. It is very slow however. Especially if the straw was coming from a combine with a large head. I have a small (13') head on my combine, and it is tough to bale behind that with the 14t. A LOT of clutch riding. With a bigger windrow of straw, you will need to just creep along. I might look for a bigger baler. A New Holland 477 in good shape should work for 30 acres of hay. Around here many Amish farmers cut 4-5 cuttings off of 30+ acres with a 7' sickle bar mower.
