replace tires for manure spreader
RonB
03-29-2004 10:46:59
I need to replace the tires off of a manure spreader. The tires are 7.00X20. 8 ply tires are perferred. Does anyone make this size tire?
The old ones are made by Kelly.
Ron in AR
03-29-2004 15:49:00
 Re: replace tires for manure spreader in reply to RonB, 03-29-2004 10:46:59
I had to replace the ones on mine not long ago. Had the same problem, couldn't find any 7.00 X 20s. I put a set of 10.00 X 20s on mine and it worked just fine. Those are really easy to find new or used. I put a set of used ones on and they will most likely last me forever and a day.
JMS/MN
03-29-2004 11:01:04
Used to be a lot of 8.00-20 truck tires used on spreaders- those are still easy to find, might fit ok, depending on your rim width. Otherwise, if you find an older (1 1/2 ton) truck in a salvage yard, it might have 7.00-20 tires. Not to common anymore. Some grain drills might have used them too.
RonB
03-30-2004 05:55:04
 Re: Re: replace tires for manure spreader in reply to JMS/MN, 03-29-2004 11:01:04
Thanks for the tips.
