Dearborn sickle mower
gspig
03-29-2004 06:13:39
I have a 14-15 model sickle mower. Is there a good online source for rock guard teeth? I have several bent and worn out. TSC has some, but the mounting hole is too close to the knife guide and the teeth point down when bolted to the bar.
wd steve
03-29-2004 18:56:46
 Re: Dearborn sickle mower in reply to gspig, 03-29-2004 06:13:39
try webbs sickle service in nebraska he has aweb page under the same name,i also own a 14-16a called him and he has every part.
Ultradog MN
03-29-2004 08:58:47
The guards should be the same for the older Dearborn mowers as they are for the newer 501 mowers. I was given a Dearborn 15-16 mower basketcase. It had 14 brand new guards on it.
Lately I've been giving my 501 a good going over - new ledger plates, a couple of seals etc. and those new guards on the Dearborn fit right on to the 501. I bought the rest of the ledger plates at the NH dealer. They should also have your guards.
BTW, if you are anywhere near the Twin Cities I'd give you the remnants of that old Dearborn. I don't plan on ever fixing it but I still hate to see it just rust away if someone could use some parts on it.
Jerry
