JD1250 planter
CHRIS
03-28-2004 21:17:58
Is this a good planter? I have 5 acres I want to plant in corn and milo. Does this planter use plates? Thanks for any help.
Jeff OH
03-29-2004 05:05:48
 Re: JD1250 planter in reply to CHRIS, 03-28-2004 21:17:58
Chris,, I used one for 5 years, It was setup for a monitor but i couldn't make it work. I plant around 60 acres corn every year, had the monitor worked I would probably have a better opinion of it, I hated spot planting where a row would quit working and I wouldn't catch it for a round or two. Also the plateless units are big and unfriendly, very time consuming to check, and clean out. sweetcorn is a real pain, you might dump 2-3 lb. in a row and not see it because the plateless units are so big. Unless you have a working monitor you will not like using it for small jobs. Another thing I hated was the chain trip markers and the fact it didn't have a jack. In all fairness it did do a decent job for me. But I've since moved on and am glad I got away from these issues. I pulled mine out of the barn last fall I haven't dedided yet whether junk it or try to sell parts. I doubt theirs too much demand for parts so I'll probably junk it.
Leroy
04-02-2004 06:02:33
 Re: Re: JD1250 planter in reply to Jeff OH, 03-29-2004 05:05:48
Where in Ohio, How many units and how much?
rickm
03-29-2004 03:59:51
Chris, I have a later model plateless one that I'm happy with. I stripped a 1240 to 'overhaul' it and it hasn't given me any problems. I know from experience that you need to thorughly clean the finger-pick-up units after each season. It plants corn,soybeans and sorghum very well. Not a bad planter(for $300.)
Oklahomatractorrebuilder
03-29-2004 06:05:36
 Re: Re: JD1250 planter in reply to rickm, 03-29-2004 03:59:51
Since you stripped a 1240 do you have any parts for sale to fit a 1240? I need 4 seed buckets for mine. Tim
rickm
03-29-2004 08:33:05
 Re: Re: Re: JD1250 planter in reply to Oklahomatractorrebuilder, 03-29-2004 06:05:36
Tim: e-mail if you like, and I'll see what's left. There may be 4 good ones. They're the rectangle ones, not the round ones.(Shipping may be a bear !) Rick
03-29-2004 22:03:55
 Re: Re: Re: Re: JD1250 planter in reply to rickm, 03-29-2004 08:33:05
I can't get your email address to load. Thanks anyway but I need the round ones. Tim
rickm
03-29-2004 03:57:33
Chris, I have a later model plateless one that I'm happy with. I stripped a 1240 to 'overhaul' it and it hasn't given me any problems. I know from experience that you need to thorughly clean the finger-pick-up units after each season. It plants corn,soybeans and sorghum very well. Not a bad planter(for) $300.
