 I'm always amused when the subject of "tillers" comes up here. There's always a lot of mis information given, and some of it, i'm sure is partly because we live in different area's of our planet. I have (3) "Howard" rotavators, (only brand i'll buy) and i do a lot of custom tillage with them. I've been rotavateing for near 20 years now with the first one i bought, adding the other two in later years. I'd say i've put more hours in the field with a tiller than "all" of the people here who have answered combined!!! I haven't come across "any ground", that "can be plowed", that my Howard "didn't do a better job", and also have that same ground ready to plant "faster" than if it's been plowed, disced, draged ect... ESPECIALLY new or reclaimed ground!! BUT, i've only rotavated in two states, not all over this planet, so your ground may be different???? First of all, there's a HUGE difference between a "garden tiller", and a "field tiller"!! Garden tillers are much more fragile, and can be tore up fairly easily especially in "stones" or by hitting other "trash" in the ground! All of the bigger Howards are "field tillers" and if sized right for your hp of tractor, you won't be tearing them up any time soon on rocks or anything else!! That's what a "properly ajusted" drive line slip clutch is for!!!! I don't agree that "gears" are better/stronger than a chain unless you are getting into 150 + hp units!! My 6' HA Howard is chain drive, and after nearly 20 years of "yearly" comercial custom tilling, it's still on it's origional chain, sprockets, and about everything else for that matter!!!! In fact, the only parts i've needed for it are, sealing washers under the bolt heads of the chain cover bolts, slip clutch plates, a few frame bolts, and a pto shaft! (other than rotor blades & bolts, and greese & oil) As for "destroying the soil"???? I can't seem to destroy my soil, and it's only seen a rotovator for many, many yeas now!!! The rye field in the picture was rotavated (again) last fall, seeded, and you can see how it's produceing this spring!! "If" these things destroy the soil, why do i, and my customers keep getting such good crops year after year????? "If" tillers are so fragile, why aren't mine breaking when i'm useing them for comcerial duty???? BUY a good brand "field tiller" sized right for your tractor, "learn how to set it for YOUR conditions", and 99.9% of all the problems you "read about" will be GONE!!!! Robert
