NH 163 Tedder
Bill B
03-22-2004 17:31:14
Hi, I just bought a NH 163 at an auction and I noticed that the coupling where the side frame finger slide into have grooves worn in them. Should I replace these coupling now? Thanks, Bill
Steve from New Holland
03-23-2004 04:33:43
 Re: NH 163 Tedder in reply to Bill B, 03-22-2004 17:31:14
Bill, my rule of thumb is: "IF they don't slip, don't replace them untill necessary. Steve
Bill B
03-23-2004 05:44:03
 Re: Re: NH 163 Tedder in reply to Steve from New Holland, 03-23-2004 04:33:43
Steve, One side is pretty worn out. One roller is gone and the shaft it fits on worn. I plan on replacing the coupling and pin and rollers on this side. Is it hard to get this coupling off ? Do you know if the parts for a JD 752 and a NH163 the same? They look the same except for color. I have ordered all the manuel from NH but havn't got them yet. JD has online parts manuels so I was able to get an idea whats going on. Their are no NH dealers in my area. Thanks, Bill
David in MD
03-23-2004 13:28:34
 Re: Re: Re: NH 163 Tedder in reply to Bill B, 03-23-2004 05:44:03
I bought a used JD 752 which is made in France by Kuhn. I know Kuhn still makes JD's newest tedders as well as NH's so I would assume the older ones might be the same machine also. I bought a new part for mine which had JD green paint over Kuhn orange.
I replaced the rollers and pins on mine when I got it. The cast couplers had some wear which I welded up and ground down. I also switched the couplers right to left so that the rollers will wear on the other side of the coupler. If I remember correctly the couplers came off by removing a snap ring or roll pin.
After buying this tedder my overall impression was that it is a marginal design that needs much more metal. The drive line parts on mine were showing more wear than the rest of the machine would indicate. My positive comment is that it does a nice job.
