4440 fuel usage per hour
Willy
03-20-2004 05:18:27
If I buy a 4440 powershift john deere tractor set at 130 horse power and pull a 20 foot international disk what can I expect for fuel usage per hour?
Indydirtfarmer
03-20-2004 15:58:58
 Re: 4440 fuel usage per hour in reply to Willy, 03-20-2004 05:18:27
I have a "stock" 4440. Last time we did any tillage work with it, I was chizel plowing. That's been 10 years ago. I used about 45 gallons of fuel in a 10 hour day. A 20' disc might pull a little easier. John
JMS/MN
03-20-2004 11:16:08
Most jobs with the 4430 around 3 1/2 to 5 gallons per hour. Whether tillage or chopping hay you should run 4-5 gallons per hour. I don't think I run over 6 with the 4450. But hey, that's only 19,000 hours experience with the two. No way you'll run 10. Neighbor's 6600 GAS combine did run 9 per hour, but the diesels are more efficient.
ChrisL
03-20-2004 09:20:04
for a John Deere I would figure 10 gallons an hour just to be a little on the safe side
he he
charlie
03-20-2004 15:24:16
 Re: Re: 4440 fuel usage per hour in reply to ChrisL, 03-20-2004 09:20:04
take maximum fly wheel hp x .035.that will get you close.good luck
