roto tiller for a 47 9N
joe
03-20-2004 05:10:42
I was wondering if I could put a tiller behind my ford 1947 9N. Will I have enough horse power and if so will I have enough rpm to do the job.
T213R
03-20-2004 09:34:42
 Re: roto tiller for a 47 9N in reply to joe, 03-20-2004 05:10:42
You ARE aware that you have a 2N and not a 9N, arn't you? They called them 9N because they were first made in 193NINE. and changed the name to 2N in 194TWO and 8N in 194EIGHT!
bob
03-20-2004 19:38:28
 Re: Re: roto tiller for a 47 9N in reply to T213R, 03-20-2004 09:34:42
Nope! I also have a 1947 9N. 9N is stamped on the engine block & 1947 mfg. date to the day is cast on the rear axle outer housing.
Rusty 2N
03-21-2004 07:28:28
 Re: Re: Re: roto tiller for a 47 9N in reply to bob, 03-20-2004 19:38:28
Nope you have a 47 2N.
bob
03-21-2004 20:50:06
 Re: Re: Re: Re: roto tiller for a 47 9N in reply to Rusty 2N, 03-21-2004 07:28:28
Whats the difference between 1947 2N & 1947 9N?
Leroy
03-22-2004 18:45:44
 Re: Re: Re: Re: Re: roto tiller for a 47 9N in reply to bob, 03-21-2004 20:50:06
There were no 9N's made after 43, only the 2N but on the serial numbers they did not change the 9 to a 2
bob
03-22-2004 21:49:39
 Re: Re: Re: Re: Re: Re: roto tiller for a 47 9N in reply to Leroy, 03-22-2004 18:45:44
OK, thanks. Glad to have that cleared up.
greenbeanman
03-20-2004 07:43:10
To be honest, the ground speed of the tractor is too great for a tiller to work properly.
