JD throw away plow shares
riverbend
03-19-2004 17:25:44
I have a 2 bottom JD 44 plow. At what point should you throw away the shares? I didn't think mine were so bad until I bought new ones. The back share was half gone and they were only about 5 years old. On the landsides, has anyone welded them up when the little triangular heel is gone ?
Ron
03-21-2004 07:51:52
 Re: JD throw away plow shares in reply to riverbend, 03-19-2004 17:25:44
You should replace any plow share Before the "frog" contacts the ground... The more the share wears, the closer the frog gets to the ground.. If you are going to weld up the landslides, I would use pieces of the worn throw away shares...
